Zum Hauptinhalt wechseln
Logitech Extreme 3D Pro Disassembly of the handle
Was du brauchst
  1. Logitech Extreme 3D Pro Disassembly of the handle, Disassembly of the handle: Schritt 1, Bild 1 von 1
    • Remove these three Phillips #1 screws:
    • Two 10mm screws.
    • One 7mm screw.
  2. Logitech Extreme 3D Pro Disassembly of the handle: Schritt 2, Bild 1 von 1
    • Using your fingers, lower the rubber boot to reveal two screws underneath the joystick.
    • Remove the two 10mm Phillips #1 screws.
  3. Logitech Extreme 3D Pro Disassembly of the handle: Schritt 3, Bild 1 von 2 Logitech Extreme 3D Pro Disassembly of the handle: Schritt 3, Bild 2 von 2
    • Pull apart the joystick chassis by hand.
    • Release this clip located underneath the hand rest
    • The circuit board will be loose and may fall down.
Abschluss
6 weitere Nutzer:innen haben diese Anleitung absolviert.
Emanuel Canela
1.297 Reputation
7 Anleitungen geschrieben
USF Tampa, Team S7-G1, Passmore Spring 2018 Mitglied von USF Tampa, Team S7-G1, Passmore Spring 2018
USFT-PASSMORE-S18S7G1
4 Mitglieder
2 Kommentare
yeah but i got this far before looking at the site, and what i really want to see is how the cotter ring pin is set on the shaft that enables the z-rot instead of locking it down.
erock steady - Antwort
if you havent worked it out already, the Z-rot spring needs spread across a little 3/8 inch tab, otherwise it will lock the axis a few degrees off center
cody Werdal -
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 11
Letzte 30 Tage: 32
Insgesamt: 3,455
