Einleitung
After a long use the joystick trigger might experience a lack of strength within the trigger's internal spring.
Was du brauchst
Remove these three Phillips #1 screws:
Two 10mm screws.
One 7mm screw.
Using your fingers, lower the rubber boot to reveal two screws underneath the joystick.
Remove the two 10mm Phillips #1 screws.
Pull apart the joystick chassis by hand.
Release this clip located underneath the hand rest
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
