Zum Hauptinhalt wechseln
Logitech Extreme 3D Pro Main Joystick Spring Replacement
Was du brauchst
  1. Logitech Extreme 3D Pro Main Joystick Spring Replacement, Disassembly of the handle: Schritt 1, Bild 1 von 1
    • Remove these three Phillips #1 screws:
    • Two 10mm screws.
    • One 7mm screw.
  2. Logitech Extreme 3D Pro Main Joystick Spring Replacement: Schritt 2, Bild 1 von 1
    • Using your fingers, lower the rubber boot to reveal two screws underneath the joystick.
    • Remove the two 10mm Phillips #1 screws.
  3. Logitech Extreme 3D Pro Main Joystick Spring Replacement: Schritt 3, Bild 1 von 2 Logitech Extreme 3D Pro Main Joystick Spring Replacement: Schritt 3, Bild 2 von 2
    • Pull apart the joystick chassis by hand.
    • Release this clip located underneath the hand rest
    • The circuit board will be loose and may fall down.
  4. Logitech Extreme 3D Pro Main Joystick Spring Replacement, Disassembly of the base: Schritt 4, Bild 1 von 1
    • Remove the eight 10mm Phillips #1 screws from the bottom.
  5. Logitech Extreme 3D Pro Main Joystick Spring Replacement: Schritt 5, Bild 1 von 3 Logitech Extreme 3D Pro Main Joystick Spring Replacement: Schritt 5, Bild 2 von 3 Logitech Extreme 3D Pro Main Joystick Spring Replacement: Schritt 5, Bild 3 von 3
    • Flip the joystick upright.
    • Lift up the sliver base cover and feed the loose circuit board through.
    • Careful with the wires still attached to the silver base cover from the bottom of the joystick.
  6. Logitech Extreme 3D Pro Main Joystick Spring Replacement, Main Joystick Spring: Schritt 6, Bild 1 von 2 Logitech Extreme 3D Pro Main Joystick Spring Replacement, Main Joystick Spring: Schritt 6, Bild 2 von 2
    • Disconnect the wire from the motherboard.
  7. Logitech Extreme 3D Pro Main Joystick Spring Replacement: Schritt 7, Bild 1 von 2 Logitech Extreme 3D Pro Main Joystick Spring Replacement: Schritt 7, Bild 2 von 2
    • Remove this plug from the motherboard.
  8. Logitech Extreme 3D Pro Main Joystick Spring Replacement: Schritt 8, Bild 1 von 2 Logitech Extreme 3D Pro Main Joystick Spring Replacement: Schritt 8, Bild 2 von 2
    • Remove the four 10mm Phillips #1 screws from the joystick base.
  9. Logitech Extreme 3D Pro Main Joystick Spring Replacement: Schritt 9, Bild 1 von 1
    • Remove the joystick assembly.
  10. Logitech Extreme 3D Pro Main Joystick Spring Replacement: Schritt 10, Bild 1 von 1
    • Remove the white plastic piece on top of the spring.
    • The white plastic will be covered in a lubricant.
  11. Logitech Extreme 3D Pro Main Joystick Spring Replacement: Schritt 11, Bild 1 von 1
    • Remove the Spring
    • The spring will be covered in lubricant.
Abschluss
5 weitere Nutzer:innen haben diese Anleitung absolviert.
Emanuel Canela
1.297 Reputation
7 Anleitungen geschrieben
USF Tampa, Team S7-G1, Passmore Spring 2018 Mitglied von USF Tampa, Team S7-G1, Passmore Spring 2018
USFT-PASSMORE-S18S7G1
4 Mitglieder
6 Kommentare
um, what kind of spring is that and where/how would I get a replacement?
Swift Foxe - Antwort
same question here
Robbert Sprezzatura -
Where can I find a replacement spring?
ande3224@bellsouth.net - Antwort
Anyone found a source for replacement springs?
Chandler - Antwort
You can cut the top 360 degrees off the spring with a Dremel cutoff tool, that reduces the work require to operate the stick by about half.
Frank Clarke - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 26
Letzte 30 Tage: 108
Insgesamt: 11,272
