Zum Hauptinhalt wechseln
Logitech Extreme 3D Pro Top button circuit board Replacement
Was du brauchst
  1. Logitech Extreme 3D Pro Top button circuit board Replacement, Disassembly of the handle: Schritt 1, Bild 1 von 1
    • Remove these three Phillips #1 screws:
    • Two 10mm screws.
    • One 7mm screw.
  2. Logitech Extreme 3D Pro Top button circuit board Replacement: Schritt 2, Bild 1 von 1
    • Using your fingers, lower the rubber boot to reveal two screws underneath the joystick.
    • Remove the two 10mm Phillips #1 screws.
  3. Logitech Extreme 3D Pro Top button circuit board Replacement: Schritt 3, Bild 1 von 2 Logitech Extreme 3D Pro Top button circuit board Replacement: Schritt 3, Bild 2 von 2
    • Pull apart the joystick chassis by hand.
    • Release this clip located underneath the hand rest
    • The circuit board will be loose and may fall down.
  4. Logitech Extreme 3D Pro Top button circuit board Replacement, Top button circuit board: Schritt 4, Bild 1 von 3 Logitech Extreme 3D Pro Top button circuit board Replacement, Top button circuit board: Schritt 4, Bild 2 von 3 Logitech Extreme 3D Pro Top button circuit board Replacement, Top button circuit board: Schritt 4, Bild 3 von 3
    • Remove the three 7mm Phillips #1 screws from the button board.
    • Remove the button board from the plastic top.
    • When taken apart the plastic buttons can fall out.
  5. Logitech Extreme 3D Pro Top button circuit board Replacement: Schritt 5, Bild 1 von 2 Logitech Extreme 3D Pro Top button circuit board Replacement: Schritt 5, Bild 2 von 2
    • Disconnect the cable from the button board.
  6. Logitech Extreme 3D Pro Top button circuit board Replacement: Schritt 6, Bild 1 von 2 Logitech Extreme 3D Pro Top button circuit board Replacement: Schritt 6, Bild 2 von 2
    • Disconnect the smaller cable from the button board.
Abschluss
4 weitere Nutzer:innen haben diese Anleitung absolviert.
Emanuel Canela
1.297 Reputation
7 Anleitungen geschrieben
USF Tampa, Team S7-G1, Passmore Spring 2018 Mitglied von USF Tampa, Team S7-G1, Passmore Spring 2018
USFT-PASSMORE-S18S7G1
4 Mitglieder
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 5
Letzte 30 Tage: 25
Insgesamt: 2,074
