Zum Hauptinhalt wechseln
Logitech G1 Optical Mouse Scroll Wheel Replacement
Was du brauchst
  1. Logitech G1 Optical Mouse Scroll Wheel Replacement, Scroll Wheel: Schritt 1, Bild 1 von 1
    • Remove one screw at the bottom of the mouse.
  2. Logitech G1 Optical Mouse Scroll Wheel Replacement: Schritt 2, Bild 1 von 2 Logitech G1 Optical Mouse Scroll Wheel Replacement: Schritt 2, Bild 2 von 2
    • Pull the top of the mouse lid gently to separate it from the rest of the mouse.
    • Potential for device damage: The lid and the body are connected with a wire, so separate them gently.
  3. Logitech G1 Optical Mouse Scroll Wheel Replacement: Schritt 3, Bild 1 von 2 Logitech G1 Optical Mouse Scroll Wheel Replacement: Schritt 3, Bild 2 von 2
    • Pull the white connector from the circuit board.
    • Be sure the two small holes in the connector are positioned at the top when reassembling.
  4. Logitech G1 Optical Mouse Scroll Wheel Replacement: Schritt 4, Bild 1 von 2 Logitech G1 Optical Mouse Scroll Wheel Replacement: Schritt 4, Bild 2 von 2
    • Carefully pull the scroll wheel up.
    • The long parts of the spring should be in the southeast and southwest directions when reassembling.
  5. Logitech G1 Optical Mouse Scroll Wheel Replacement: Schritt 5, Bild 1 von 2 Logitech G1 Optical Mouse Scroll Wheel Replacement: Schritt 5, Bild 2 von 2
    • Carefully remove the two Phillips #0 screws.
  6. Logitech G1 Optical Mouse Scroll Wheel Replacement: Schritt 6, Bild 1 von 2 Logitech G1 Optical Mouse Scroll Wheel Replacement: Schritt 6, Bild 2 von 2
    • Clean the mouse case, lid, and module with a dry cotton swab or soft brush.
    • Potential for device damage: Do not use water or an iron brush to clean it.
  7. Logitech G1 Optical Mouse Scroll Wheel Replacement: Schritt 7, Bild 1 von 2 Logitech G1 Optical Mouse Scroll Wheel Replacement: Schritt 7, Bild 2 von 2
    • Place the new scroll wheel into the mouse.
  8. Logitech G1 Optical Mouse Scroll Wheel Replacement: Schritt 8, Bild 1 von 1
    • The spring should be inserted into a small groove.
    • The spring can be inserted after combining the mouse body.
Ziellinie
2 weitere Nutzer:innen haben diese Anleitung absolviert.
York University, Team S1-G33, Woodhouse Winter 2021 Mitglied von York University, Team S1-G33, Woodhouse Winter 2021
YORK-WOODHOUSE-W21S1G33
1 Mitglied
2 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 6
Letzte 7 Tage: 9
Letzte 30 Tage: 23
Insgesamt: 1,250
