Was du brauchst
Using a heat gun or a blow dryer, warm the pads at the 2 top corners of the bottom of the mouse.
Remove the pads once heated (will be easier when warm).
There will be screws located under the pads. Use a Phillips #00 screwdriver to remove the case screws.
Pull the top half towards the front of the mouse where the left and right mouse buttons are located.
6 weitere Personen haben diese Anleitung absolviert.
