Zum Hauptinhalt wechseln
Logitech G29 Driving Force Force-Feedback Motor Replacement
Was du brauchst
  1. Logitech G29 Driving Force Force-Feedback Motor Replacement, Force-Feedback Motor: Schritt 1, Bild 1 von 1
    • Remove the six 32 mm hex screws from the faceplate of the steering wheel.
  2. Logitech G29 Driving Force Force-Feedback Motor Replacement: Schritt 2, Bild 1 von 1
    • Remove the six 10 mm #00 Phillips screws from the back of the steering wheel.
    • Gently lift off the steering wheel from the hub.
  3. Logitech G29 Driving Force Force-Feedback Motor Replacement: Schritt 3, Bild 1 von 1
    • Carefully unplug the wire connector from the motherboard of the steering wheel.
  4. Logitech G29 Driving Force Force-Feedback Motor Replacement: Schritt 4, Bild 1 von 2 Logitech G29 Driving Force Force-Feedback Motor Replacement: Schritt 4, Bild 2 von 2
    • Using the #2 Phillips head screwdriver remove the three 30mm long screws that are behind the steering wheel.
    • Gently pull the paddle assembly off from the base of the device and carefully thread the connector through the hole in the center.
  5. Logitech G29 Driving Force Force-Feedback Motor Replacement: Schritt 5, Bild 1 von 1
    • Remove the six 15.9mm long silver screws on the bottom of the base of the wheel with a Phillips #1 screwdriver.
  6. Logitech G29 Driving Force Force-Feedback Motor Replacement: Schritt 6, Bild 1 von 1
    • Now remove the four 7.3mm long silver screws from the motherboard using a Phillips #2 screwdriver.
    • Then, carefully remove the seven plastic connectors from the motherboard. Make sure to avoid pulling by the wires and to only pull on the plastic
  7. Logitech G29 Driving Force Force-Feedback Motor Replacement: Schritt 7, Bild 1 von 1
    • Remove the two black screws using a Phillips #2 screwdriver.
  8. Logitech G29 Driving Force Force-Feedback Motor Replacement: Schritt 8, Bild 1 von 1
    • Remove the four 12 mm screws with the Phillips #1 screwdriver.
  9. Logitech G29 Driving Force Force-Feedback Motor Replacement: Schritt 9, Bild 1 von 1
    • Now that the complete driving assembly is out you can replace it as needed.
Abschluss
4 weitere Personen haben diese Anleitung absolviert.
Isaac Seagle
433 Reputation
2 Anleitungen geschrieben
4 Kommentare
how much is this part
glenn castillo - Antwort
where do u get repayment parts ?
callum smith - Antwort
Where can we find some replacments parts ?
super miaoumix - Antwort
I’d like to disconnect those two motors because at night, when my family is sleeping, they make a lot of noise and I really don’t want to wake anyone up.
Is it possible to open up the G29, cut or unplug those motor cables, and still have everything else work properly?
David Martinez - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 12
Letzte 7 Tage: 87
Letzte 30 Tage: 328
Insgesamt: 11,563
