Einleitung
This guide is to show how to replace the two force-feedback motors on the Logitech G29 Driving Force. The Force-feedback motors are what put the resistance on the steering wheel based on what is happening in the game. If these motors go out it can cause the steering wheel to not register the steering inputs that you are putting in.
Was du brauchst
Remove the six 32mm long 4mm allen screws from the faceplate of the steering wheel
Now, Remove the six 10mm long #00 Phillips head screws from the back of the steering wheel.
Using the #1 Phillips head screwdriver remove the three 30mm long screws that are behind the steering wheel.
Remove the 15.9mm long silver screws on the bottom of the base of the wheel with a Phillips #1 screwdriver.
Now remove the four 7.3mm long silver screws from the motherboard using a Phillips #2 screwdriver.
Then, carefully remove the seven plastic connectors from the motherboard. Make sure to avoid pulling by the wires and to only pull on the plastic
2 weitere Nutzer:innen haben diese Anleitung absolviert.
3 Kommentare
how much is this part
where do u get repayment parts ?
Where can we find some replacments parts ?
