Zum Hauptinhalt wechseln
Logitech G29 Driving Force Pedal Replacement
Was du brauchst
  1. Logitech G29 Driving Force Pedal Replacement, Pedal: Schritt 1, Bild 1 von 1
    • Start by removing the 12 #1 Phillips that holds the pedals the the back board
  2. Logitech G29 Driving Force Pedal Replacement: Schritt 2, Bild 1 von 1
    • Next remove all 12 of the J0 Phillips
  3. Logitech G29 Driving Force Pedal Replacement: Schritt 3, Bild 1 von 1
    • For the last Couple screws remove the 2, 2.5 Allans located on the pedals.
    • I would suggest only taking the 2 Allans out of the pedal that needs fixing. All others can stay
  4. Logitech G29 Driving Force Pedal Replacement: Schritt 4, Bild 1 von 1
    • Now that all screws are loose the back plate should be able to be removed reviling the pedals.
  5. Logitech G29 Driving Force Pedal Replacement: Schritt 5, Bild 1 von 1
    • If pedal is unresponsive start by checking the gear mesh.
    • If gear mesh is not connecting check to make sure everything is tight.
    • If gears are stripped or broken off get replacement gears.
  6. Logitech G29 Driving Force Pedal Replacement: Schritt 6, Bild 1 von 1
    • If gears are fine check wire connections.
    • If red wires are loose resouder and make sure the connection is good.
    • If the black ground wire is loose, tighten up.
    • If none of these fix the problem go ahead and source a new pedal to install.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 7
Letzte 7 Tage: 56
Letzte 30 Tage: 227
Insgesamt: 3,592
