Einleitung
This replacement is not bad other than the fact there are a ton of screws. With a little soldering knowledge and fixing knowledge this guide will take you through the steps needed to replace a pedal.
Was du brauchst
Start by removing the 12 #1 Phillips that holds the pedals the the back board
For the last Couple screws remove the 2, 2.5 Allans located on the pedals.
I would suggest only taking the 2 Allans out of the pedal that needs fixing. All others can stay
If red wires are loose resouder and make sure the connection is good.
If the black ground wire is loose, tighten up.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
