Was du brauchst
Use a flathead screwdriver or your fingernail to remove the mouse feet.
Be careful to remove any film left by the mouse feet as well.
Remove the bottom mouse foot using a Jimmy and the same technique as in Step 1.
Use a Phillips #1 screwdriver to remove the three 5 mm Philips screws on the bottom surface.
Simply lift the scroll wheel out of the compartment it sits in. It can then be cleaned or replaced as desired.
2 weitere Personen haben diese Anleitung absolviert.
