Zum Hauptinhalt wechseln
Logitech G533 Headphones doesnt work without USB cable
Was du brauchst
    • If the power button lits up only if the USB cable is plugged in. You probably have a loosened power cable inside the left earcup.
    • If your headphones still have a warranty, just return them to the shop.
    • Before you start disassembling try all the guides on the official website to make sure your problem is not software-based.
  1. Logitech G533 Headphones  doesnt work without USB cable: Schritt 4, Bild 1 von 1
    • Take out the left earcup padding. Turn the right side of the earcup counterclockwise and unplug the battery.
  2. Logitech G533 Headphones  doesnt work without USB cable: Schritt 5, Bild 1 von 1
    • Unscrew 4 screws with Torx Security TR8 bit.
  3. Logitech G533 Headphones  doesnt work without USB cable: Schritt 6, Bild 1 von 1
    • Carefully move aside the speaker. There are very thin wires connected to it and the printed circuit.
    • Unscrew the 5 screws marked on the picture with Philips 0 bit.
  4. Logitech G533 Headphones  doesnt work without USB cable: Schritt 7, Bild 1 von 1
    • Loosen the screw on the picture and slide up the black top under it.
  5. Logitech G533 Headphones  doesnt work without USB cable: Schritt 8, Bild 1 von 1
    • Take out the middle frame piece.
    • You will need to push the speaker through the frame and take out the mic off the frame.
  6. Logitech G533 Headphones  doesnt work without USB cable: Schritt 9, Bild 1 von 1
    • Here you can see that the red power cable is loosened.
  7. Logitech G533 Headphones  doesnt work without USB cable: Schritt 10, Bild 1 von 1
    • It looks like the cables are not soldered to the printed circuit. Just glued to it.
    • Scrap off the glue. I used a scalpel.
  8. Logitech G533 Headphones  doesnt work without USB cable: Schritt 11, Bild 1 von 1
    • You can plug back the battery and hold the cable in its original place.
    • Switch the power button and the power light should turn on.
    • The light will turn on after 2 seconds. You will need to keep the cable in place the whole time.
  9. Logitech G533 Headphones  doesnt work without USB cable: Schritt 12, Bild 1 von 1
    • Now you have two options. You can glue the cable back in and risk it will get loosen again. Or solder it.
    • The weld on the picture was so crappy that the cable get off when I was assembling it back. And have to redo it.
  10. Logitech G533 Headphones  doesnt work without USB cable: Schritt 13, Bild 1 von 1
    • When I was assembling the headphones I noticed that the mic cable get partially naked. It happened because every time you move the mic leg the cable has contact with the insides of the earcup.
    • I recommend putting electrical tape over it or don't move the mic leg at all. Just use the mute button on the back of the left earcup.
Abschluss
7 weitere Nutzer:innen haben diese Anleitung absolviert.
Kobda
427 Reputation
1 Anleitung geschrieben
8 Kommentare
Hi, its possible to disassembly the mic to change the cable? Mine its cut in the middle and I need to replace
Sauron666 - Antwort
Can you please link a picture of the problem? It will be easier for me to assess the problem.
Kobda -
I have just taken apart the headphone because I have a similar problem, but I could not access the cable inside the microphone 'arm' without doing something that I thought might break it... Judging from the build quality inside I also think that it would be a pain in the a** to replace and fix it.
Miguel -
yep, my mic cable also broke, didnt even try to fix it and rather bought external mic.
Kobda -
Amazing guide, I was able to fix my headset to work with batteries again. Can't believe Logitech decided to glue the cables...
Daniel Barelli - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 4
Letzte 7 Tage: 39
Letzte 30 Tage: 170
Insgesamt: 5,184
