Zum Hauptinhalt wechseln
Logitech G602 Scroll Wheel Replacement
Was du brauchst
  1. Logitech G602 Scroll Wheel Replacement, Scroll Wheel Spring: Schritt 1, Bild 1 von 1
    • Use a blue spudger to pry off all 4 mouse feet from under of mouse.
  2. Logitech G602 Scroll Wheel Replacement: Schritt 2, Bild 1 von 1
    • Use a Phillips #00 screwdriver to unscrew all 6 screws (3x5mm ) from under the mouse feet.
  3. Logitech G602 Scroll Wheel Replacement: Schritt 3, Bild 1 von 2 Logitech G602 Scroll Wheel Replacement: Schritt 3, Bild 2 von 2
    • Lift the top of the mouse from the base of the mouse (separate the mouse in half) to expose the internal hardware.
  4. Logitech G602 Scroll Wheel Replacement: Schritt 4, Bild 1 von 1
    • Use the black spudger to move the tip of the metal spring off of the wheel.
    • The scroll wheel will not actually be removed — instead, the adjustment to the metal spring will test the wheel's usability.
Abschluss
8 weitere Nutzer:innen haben diese Anleitung absolviert.
2 Kommentare
I recently received an approximately 2 year old Logitech g602 mouse. Its scroll is non-functional, either up or down. I do seem to be able to scroll minimally if I press the scroll wheel down. I was wondering if you know how this might be fixed. Anything is appreciated.
Adrian Thomas Rodriguez - Antwort
I need a new wheel for this mouse. Where can I buy it? I could not see anyone who sell it
Josefa Parafina - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 14
Letzte 30 Tage: 65
Insgesamt: 7,995
