Einleitung
This guide will walk you through taking apart your Logitech G602 and replacing the side motherboard. You'll need a Phillips #00 screwdriver and a couple plastic opening tools to complete this guide.
Was du brauchst
Use a blue spudger to pry all 4 mice feet from the bottom of the mouse.
Use a Phillips #00 screwdriver to unscrew all 6 screws (3x5mm) from underneath the mice feet.
Use the blue spudger to prop open the bottom battery port.
Remove the AA batteries.
Lift the top of the mouse from the base of the mouse (separate the mouse in half) to expose the internal hardware.
Use a Phillips #00 screwdriver to remove both screws (3x5mm ) from above the side motherboard.
Use a Phillips #00 screwdriver and unscrew both screws from the side motherboard.
Use a black spudger and your fingers to loosen and remove the side motherboard.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
