Einleitung
If your battery will no longer accept a charge and you need to replace the battery, you can do so with this guide. For this guide, you will need a T4 Torx screwdriver and a spudger. This is a popular repair and it is very easy to do!
Was du brauchst
Gently pull the right ear pad off, starting from the top.
Slide your finger around the edges until it releases completely.
Remove the ear pad.
Remove the four screws securing the speaker housing using the Phillips screwdriver.
Lift off the speaker housing with care not to strain the connected cable.
Gently wiggle the battery cable side to side while pulling it out to disconnect the battery.
To reassemble your device, please follow these instructions in reverse order.
3 weitere Nutzer:innen haben diese Anleitung absolviert.
3 Kommentare
This guide is great, but mentioning what kind of battery to purchase for the headset would make it infinitely better...
I fully agree
Its a 1.5 phillips on the right side. On the left side its a T5 screw not a T4. And you can easily remove the battery without a spudger. It came out with my bare hands.
