Zum Hauptinhalt wechseln
Logitech G733 Power Button Replacement
Was du brauchst
  1. Logitech G733 Power Button Replacement, Power Button: Schritt 1, Bild 1 von 1
    • Before you begin, discharge the headset battery below 25%. A charged lithium-ion battery can catch fire and/or explode if accidentally punctured.
    • Gently start to pull the left ear pad off, starting from the top.
    • Slide your finger around the edges until it releases completely.
    • Remove the ear pad.
  2. Logitech G733 Power Button Replacement: Schritt 2, Bild 1 von 2 Logitech G733 Power Button Replacement: Schritt 2, Bild 2 von 2
    • Remove the four screws securing the speaker housing using a T4 Torx screwdriver.
    • Place these screws on the magnetic project mat so you don't lose them.
  3. Logitech G733 Power Button Replacement: Schritt 3, Bild 1 von 3 Logitech G733 Power Button Replacement: Schritt 3, Bild 2 von 3 Logitech G733 Power Button Replacement: Schritt 3, Bild 3 von 3
    • Gently lift off the speaker housing, with care not to strain the connected cable.
    • Remove the screw on the bottom right-hand side of the motherboard using a Phillips #000 screwdriver.
    • Use your thumb to gently pull back the tab at the upper right-hand corner of the headphone and simultaneously pull the circuit board out.
    • The scroll wheel may fly out when you pop the circuit board out.
  4. Logitech G733 Power Button Replacement: Schritt 4, Bild 1 von 2 Logitech G733 Power Button Replacement: Schritt 4, Bild 2 von 2
    • Once the motherboard is loose, gently pull the wire out of its harness.
    • The wiring harness is glued, so be careful with it. It should pull out easily.
  5. Logitech G733 Power Button Replacement: Schritt 5, Bild 1 von 1
    In diesem Schritt verwendetes Werkzeug:
    Halberd Spudger
    $2.99
    • Pop the power button out of its recess by pushing it through the side of the headphone with your finger.
    • Now use the hook end of the halberd spudger to pry the connecting piece of the power button off at the end furthest to the inside of the headphone.
    • This step is the most difficult, so be careful when prying.
Abschluss
Eine weitere Person hat diese Anleitung absolviert.
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 4
Letzte 7 Tage: 25
Letzte 30 Tage: 92
Insgesamt: 2,438
