Einleitung
This replacement guide will help you in replacing a faulty or broken back pedal on the Logitech G920 Driving Force. The following steps can be used for any of the three pedals that need to be replaced.
Was du brauchst
Use a Hex 2.5 screwdriver or Allen key to remove the two 30 mm center screws in the pedal.
Remove the 12 12mm screws from the bottom of the device using a Phillips #1 screwdriver.
Remove the eight 12 mm screws from the bottom of the device with a Phillips #0 screwdriver.
Push down the switch found in the hole at the top of the underside of the pedal board.
Remove the two 14 mm screws behind the carpet hold with a Phillips #0 screwdriver.
Remove the red piece, spring, and block within the pedal back.
Replace the necessary part.
2 weitere Personen haben diese Anleitung absolviert.
