Einleitung
Use this guide to replace the motor's motherboard for your Logitech G920 Driving Force Steering Wheel.
Was du brauchst
Use the Phillips #0 screwdriver to remove the five 9.5 mm external screws.
Using the Phillips #0 screwdriver, remove the 5 mm screws holding the bumpers in place.
Using the TR25 Torx Security Screwdriver, remove the six 23.8 mm screws holding the face plate together.
Remove the face plate from the steering wheel.
Flip the motor box over.
Remove the twelve 12.2 mm screws with a Phillips #0 screwdriver.
Remove the two 11.5 mm screws with a Phillips #0 screwdriver.
Remove the four 5 mm screws with a Phillips #0 screwdriver.
Detach the wires connected to the motherboard.
Remove the motherboard from the motor box.
