Zum Hauptinhalt wechseln
Logitech Gamepad F310 Buttons Replacement
Was du brauchst
  1. Logitech Gamepad F310 Buttons Replacement, Case: Schritt 1, Bild 1 von 2 Logitech Gamepad F310 Buttons Replacement, Case: Schritt 1, Bild 2 von 2
    • Use a Phillips #1 screwdriver to remove all seven 3 mm screws that secure the rear case.
    Frag FixBot
    Kommentar hinzufügen
  2. Logitech Gamepad F310 Buttons Replacement: Schritt 2, Bild 1 von 2 Logitech Gamepad F310 Buttons Replacement: Schritt 2, Bild 2 von 2
    • Press along the seams of the controller and gently pull the front and rear case apart.
    • If necessary, use an opening tool to help pry the front and rear case apart.
    • Make sure to open the controller with the front facing down so that the buttons do not fall out.
    Frag FixBot
  3. Logitech Gamepad F310 Buttons Replacement: Schritt 3, Bild 1 von 1
    • Separate the front and rear case.
    • There are two side panels on the controller that come apart as well. When putting them back together, they slot into place on the sides of the controller.
    Frag FixBot
  4. Logitech Gamepad F310 Buttons Replacement, Buttons: Schritt 4, Bild 1 von 2 Logitech Gamepad F310 Buttons Replacement, Buttons: Schritt 4, Bild 2 von 2
    • Remove any buttons that need replacement.
    • The buttons sit loosely in the front of the controller, so flipping the front over will drop all of the buttons out.
    Frag FixBot
Abschluss
You're all finished! To reassemble your device, follow these instructions in reverse order.
1 Kommentar zur Anleitung
Any idea where I can get the d-pad rubber dome replacement part?
Anggoro Arif Junianto - Antwort Teilen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 19
Letzte 30 Tage: 73
Insgesamt: 1,399
