Zum Hauptinhalt wechseln
Logitech Gamepad F310 D-Pad Replacement
Was du brauchst
  1. Logitech Gamepad F310 D-Pad Replacement, Case: Schritt 1, Bild 1 von 2 Logitech Gamepad F310 D-Pad Replacement, Case: Schritt 1, Bild 2 von 2
    • Use a Phillips #1 screwdriver to remove all seven 3 mm screws that secure the rear case.
    Frag FixBot
    Kommentar hinzufügen
  2. Logitech Gamepad F310 D-Pad Replacement: Schritt 2, Bild 1 von 2 Logitech Gamepad F310 D-Pad Replacement: Schritt 2, Bild 2 von 2
    • Press along the seams of the controller and gently pull the front and rear case apart.
    • If necessary, use an opening tool to help pry the front and rear case apart.
    • Make sure to open the controller with the front facing down so that the buttons do not fall out.
    Frag FixBot
  3. Logitech Gamepad F310 D-Pad Replacement: Schritt 3, Bild 1 von 1
    • Separate the front and rear case.
    • There are two side panels on the controller that come apart as well. When putting them back together, they slot into place on the sides of the controller.
    Frag FixBot
  4. Logitech Gamepad F310 D-Pad Replacement, D-Pad: Schritt 4, Bild 1 von 3 Logitech Gamepad F310 D-Pad Replacement, D-Pad: Schritt 4, Bild 2 von 3 Logitech Gamepad F310 D-Pad Replacement, D-Pad: Schritt 4, Bild 3 von 3
    • Remove the silver 3 mm screw in the middle of the D-pad with a Phillips #1 screwdriver.
    • Remove the D-pad
    • There are 4 buttons that go in the four slots of the D-pad, a spring on one side, and the D-Pad on the other side.
    Frag FixBot
Abschluss
This is how to replace a D-Pad on a Logitech Gamepad F310. To reassemble your device, follow these instructions in reverse order.
2 weitere Personen haben diese Anleitung absolviert.
0 Kommentare zur Anleitung
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 13
Letzte 30 Tage: 82
Insgesamt: 1,184
