Zum Hauptinhalt wechseln
Logitech Harmony 300 Batteries Replacement
Was du brauchst
  1. Logitech Harmony 300 Batteries  Replacement, Identifying the Battery Housing: Schritt 1, Bild 1 von 1
    • On the back bottom of the controller, a housing holds the batteries that are used to power the controller.
  2. Logitech Harmony 300 Batteries  Replacement, Removing the Battery Cap: Schritt 2, Bild 1 von 1
    • Place a finger on the top of the cap on the indent. While holding the controller with the other hand, press firmly towards the bottom of the controller to loosen the cap.
    • Once the cap is loosen, simply lift the cap out to reveal the batteries.
  3. Logitech Harmony 300 Batteries  Replacement, The Batteries: Schritt 3, Bild 1 von 2 Logitech Harmony 300 Batteries  Replacement, The Batteries: Schritt 3, Bild 2 von 2
    • Carefully pull the black tap to remove the batteries from the battery housing. When inserting new batteries, be aware of the correct orientation.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
USF Tampa, Team 1-29, Donnelly Fall 2014 Mitglied von USF Tampa, Team 1-29, Donnelly Fall 2014
USFT-DONNELLY-F14S1G29
1 Mitglied
1 Anleitung geschrieben
5 Kommentare
i bought Harmony 350, and it's imposibble to open this cover, I tried to open this cover for few hours wihout luck, my fingers hurt. Return this crap to shop, I have also Harmony 700 which in it cover open easy.
peter.mac83 - Antwort
This instruction is USELESS the catch is too strong! Note all the other questions about the enclosure.
Errol - Antwort
it’s impossible !!!
Pascal jade - Antwort
I agree with the other comments. I’ll keep trying, but so far after 10 minutes I still can’t get the cover to budge.
Barry Boehm - Antwort
pefI too found the battery cover impossible to remove “by hand”. I used the clear plastic package as a cradle for the device,
then used a flat-blade screwdriver applied to the indent where you are meant to push by hand, and pushed hard at about
about a 45° angle. Finally got it open! I filed off a bit of the hook on the cover latch so hopfully it will be easier next time.
Dave Davy - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 7
Letzte 30 Tage: 20
Insgesamt: 2,259
