Zum Hauptinhalt wechseln
Logitech Harmony 650 Case Replacement
Was du brauchst
  1. Logitech Harmony 650 Case Replacement, Case: Schritt 1, Bild 1 von 2 Logitech Harmony 650 Case Replacement, Case: Schritt 1, Bild 2 von 2
    • Remove the battery cover by applying pressure to the indented area and pushing the cover toward the rear of the device.
  2. Logitech Harmony 650 Case Replacement: Schritt 2, Bild 1 von 1
    • Remove the batteries using the silver pull tab.
  3. Logitech Harmony 650 Case Replacement: Schritt 3, Bild 1 von 1
    • Using a J000 Philips head screwdriver remove the four 5mm screws around the rim of the battery chamber.
  4. Logitech Harmony 650 Case Replacement: Schritt 4, Bild 1 von 1
    In diesem Schritt verwendetes Werkzeug:
    Flathead 3/32" or 2.5 mm Screwdriver
    $5.49
    Kaufen
    • Remove the small plastic cover beneath the plastic LED housing by using a 3.0 flathead screwdriver and a spudger to pry it off. It is glued to the case. If you are having trouble removing it try applying some heat to loosen the glue.
  5. Logitech Harmony 650 Case Replacement: Schritt 5, Bild 1 von 1
    • Remove the two 5mm screws located underneath the cover using a J000 Philips screwdriver bit.
  6. Logitech Harmony 650 Case Replacement: Schritt 6, Bild 1 von 2 Logitech Harmony 650 Case Replacement: Schritt 6, Bild 2 von 2
    • Using a plastic opening tool, pry the case off starting from the top of the device (nearest the transmitter). There are 3 tabs along the side of the case and one at the back.
    • The top led protector plastic cover will also be freed once back is removed.
  7. Logitech Harmony 650 Case Replacement: Schritt 7, Bild 1 von 1
    • Remove the rear cover.
Abschluss
4 weitere Nutzer:innen haben diese Anleitung absolviert.
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 5
Letzte 7 Tage: 10
Letzte 30 Tage: 25
Insgesamt: 2,892
