Was du brauchst
Use the Opening Tool to open the port cover at the bottom of the remote control.
Bend the cover back to gain easy access to the screws.
Use the Phillips #0 Screwdriver to remove the (2) two 6mm screws.
Pull the bottom cover off of the remote control.
Use the Phillips #1 Screwdriver to remove the (2) two 6mm screws.
There should be a gap on each side to fit the Opening Tool. Use the Opening Tool to open the back cover (Soft Touch cover) using the gap.
Use the Opening Tool to lift the battery out of the case.
Gently pull the cable out of the socket to unplug the battery.
Use the Phillips #0 screwdriver to remove the (3) three 6mm screws.
Push the opening tool into the gap along the side of the remote, then slide it across until you hear clicking sounds.
In diesem Schritt verwendetes Werkzeug:Tweezers$3.99
Use the angled Tweezers to carefully pull the white cable end off of the remote and disconnect it.
Remove the black tape to access the cable underneath.
Use the Angled Tweezers to lift the black lock.
Slide the yellow cable to disconnect it from the circuit board.
Pull the circuit board off of the remote from the bottom, and lift up to detach it from the cover.
Eine weitere Person hat diese Anleitung absolviert.
3 Kommentare
How replace A Mitsubishi Remote Control
How replace A Mitsubishi Remote Control ?
Thanks
Air conditioning
