Zum Hauptinhalt wechseln
Logitech Harmony Smart Control Remote Buttons Replacement
Was du brauchst
  1. Logitech Harmony Smart Control Remote Buttons Replacement, Remote Buttons: Schritt 1, Bild 1 von 2 Logitech Harmony Smart Control Remote Buttons Replacement, Remote Buttons: Schritt 1, Bild 2 von 2
    • With both thumbs, slide the grooved cover off the end of the remote.
    • Remove the battery once cover is removed.
  2. Logitech Harmony Smart Control Remote Buttons Replacement: Schritt 2, Bild 1 von 2 Logitech Harmony Smart Control Remote Buttons Replacement: Schritt 2, Bild 2 von 2
    • With the PH00 bit, remove both of the 4mm Phillip screws on the remote.
  3. Logitech Harmony Smart Control Remote Buttons Replacement: Schritt 3, Bild 1 von 2 Logitech Harmony Smart Control Remote Buttons Replacement: Schritt 3, Bild 2 von 2
    • Using a metal spudger, pry the remote. Maneuver around to separate both sides.
  4. Logitech Harmony Smart Control Remote Buttons Replacement: Schritt 4, Bild 1 von 3 Logitech Harmony Smart Control Remote Buttons Replacement: Schritt 4, Bild 2 von 3 Logitech Harmony Smart Control Remote Buttons Replacement: Schritt 4, Bild 3 von 3
    • Manualy separate the two pieces of plastic.
    • Using the metal piece from the housing, pry up the circuit board. Do not disconnect anything.
    • When the circuit board is pried, slide the circuit board out of the housing.
  5. Logitech Harmony Smart Control Remote Buttons Replacement: Schritt 5, Bild 1 von 1
    • From the front of the remote, remove the buttons. Clean or replace the necessary buttons.
Abschluss
2 weitere Nutzer:innen haben diese Anleitung absolviert.
Josh Hendricks
464 Reputation
4 Anleitungen geschrieben
IUPUI, Team 3-2, Harley Fall 2015 Mitglied von IUPUI, Team 3-2, Harley Fall 2015
IUPUI-HARLEY-F15S3G2
4 Mitglieder
5 Anleitungen geschrieben
9 Kommentare
Excellent guide. However, I can’t find a supplier for the button pad. Any suggestions?
fhaist - Antwort
Hi there,
My son dropped mine in water. I opened it and dried it off but it still doesn’t work.
I could give you my button pad if you want.
Benoit Lagarde -
Where do you purchase button replacements?
Steve Lutes - Antwort
Flavio Campos - Antwort
Excellent! I wasn’t sure if it was possible to crack it open or not. Thanks, I was able to clean it up.
John Wall - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 5
Letzte 30 Tage: 45
Insgesamt: 5,646
