Was du brauchst
With both thumbs, slide the grooved cover off the end of the remote.
Remove the battery once cover is removed.
Manualy separate the two pieces of plastic.
Using the metal piece from the housing, pry up the circuit board. Do not disconnect anything.
When the circuit board is pried, slide the circuit board out of the housing.
From the front of the remote, remove the buttons. Clean or replace the necessary buttons.
2 weitere Personen haben diese Anleitung absolviert.
9 Kommentare zur Anleitung
Excellent guide. However, I can’t find a supplier for the button pad. Any suggestions?
Hi there,
My son dropped mine in water. I opened it and dried it off but it still doesn’t work.
I could give you my button pad if you want.
Where do you purchase button replacements?
