Einleitung
This is a replacement guide for the on/off switch on the Logitech Harmony Smart Keyboard.
The on/off switch, or power switch, powers the keyboard on and off. The on/off switch appears green when powered on, and appears red when powered off.
Was du brauchst
Peel off the center sticker to reveal two hidden 4.0 mm screws.
Unscrew these two screws with a Phillips #1 screwdriver.
Lift both top left and top right rubber stickers halfway, using the sharp end of the plastic spudger.
Unscrew a total of two 4.0 mm screws, under the rubber stickers, using a Phillips #1 screwdriver.
Unscrew the top center 4.0 mm screw, in the battery compartment, using the Phillips #1 screwdriver.
Wedge the flat end of the spudger between the back panel and front panel.
Slide the flat end of the spudger from right to left to pry the two panels apart.
Grip the lower end of the ribbon flex cable (white band) using your thumb and index finger.
Then slide the strip out toward yourself in a scooping motion.
Set aside the front panel and locate the green card atop the on/off switch on the back panel.
Unscrew the two 4.0 mm screws on either side of the green card using a Phillips #1 screwdriver.
Lift up and hold the left side of the green card with one index finger.
Grip and pull the on/off switch out with your other index finger and thumb.
2 weitere Nutzer:innen haben diese Anleitung absolviert.
Ein Kommentar
please share switch rear side.. and where could we buy this switch.. ?
