Zum Hauptinhalt wechseln
Logitech Harmony Touch Buttons Replacement
Was du brauchst
  1. Logitech Harmony Touch Buttons Replacement, Buttons: Schritt 1, Bild 1 von 3 Logitech Harmony Touch Buttons Replacement, Buttons: Schritt 1, Bild 2 von 3 Logitech Harmony Touch Buttons Replacement, Buttons: Schritt 1, Bild 3 von 3
    • Open the latch that accesses the charging port.
    • Remove the black sticker and the screw with the Phillips #0 Screwdriver.
    • Take the plastic opening tool and run it down the side of the remote to open the case.
    • While doing this step, three wires connect the two pieces, be sure not to rip them out.
    • Detach the white clamp to disconnect the case from the motherboard partially.
  2. Logitech Harmony Touch Buttons Replacement: Schritt 2, Bild 1 von 3 Logitech Harmony Touch Buttons Replacement: Schritt 2, Bild 2 von 3 Logitech Harmony Touch Buttons Replacement: Schritt 2, Bild 3 von 3
    • Peel back the thin yellow plastic film.
    • Detach the clip found underneath the film.
    • Remove the screws that connect the motherboard to the case with the Phillips #0 Screwdriver.
  3. Logitech Harmony Touch Buttons Replacement: Schritt 3, Bild 1 von 3 Logitech Harmony Touch Buttons Replacement: Schritt 3, Bild 2 von 3 Logitech Harmony Touch Buttons Replacement: Schritt 3, Bild 3 von 3
    • Next, carefully remove the motherboard from the top piece of the case.
    • The motherboard is connected to the bottom part of the case.
    • You should now be able to access all the buttons and remove them from the case.
  4. Logitech Harmony Touch Buttons Replacement: Schritt 4, Bild 1 von 2 Logitech Harmony Touch Buttons Replacement: Schritt 4, Bild 2 von 2
    • Remove the buttons from the case.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
USF Tampa, Team S4-G2, Eyestone Fall 2017 Mitglied von USF Tampa, Team S4-G2, Eyestone Fall 2017
USFT-EYESTONE-F17S4G2
4 Mitglieder
5 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 9
Letzte 30 Tage: 32
Insgesamt: 1,322
