Zum Hauptinhalt wechseln
Logitech Harmony Touch Motherboard Replacement
Was du brauchst
  1. Logitech Harmony Touch Motherboard Replacement, Motherboard: Schritt 1, Bild 1 von 3 Logitech Harmony Touch Motherboard Replacement, Motherboard: Schritt 1, Bild 2 von 3 Logitech Harmony Touch Motherboard Replacement, Motherboard: Schritt 1, Bild 3 von 3
    • Open the latch that accesses the charging port
    • Remove the black sticker and remove the screw with the indicated screwdriver
    • Take the plastic opening tool and run it down the side of the remote to pop the case open
    • While doing this step there are three wires that connect the two pieces, be sure not to rip them out
    • Detach the white clamp to partially disconnect the case from the motherboard
  2. Logitech Harmony Touch Motherboard Replacement: Schritt 2, Bild 1 von 3 Logitech Harmony Touch Motherboard Replacement: Schritt 2, Bild 2 von 3 Logitech Harmony Touch Motherboard Replacement: Schritt 2, Bild 3 von 3
    • Peel back thin yellow plastic film and detach the clip found underneath
    • Remove the screws that connect the motherboard to the case with the suggested screwdriver
    • Next, carefully remove the motherboard from the top piece of the case
    • The motherboard is connected to the bottom part of the case
    • You should now be able to access all of the buttons and remove them from the case
Abschluss
USF Tampa, Team S4-G2, Eyestone Fall 2017 Mitglied von USF Tampa, Team S4-G2, Eyestone Fall 2017
USFT-EYESTONE-F17S4G2
4 Mitglieder
5 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 5
Letzte 30 Tage: 10
Insgesamt: 698
