Zum Hauptinhalt wechseln
Logitech Harmony Touch Power Adapter Replacement
Was du brauchst
  1. Logitech Harmony Touch Power Adapter Replacement, Power Adapter: Schritt 1, Bild 1 von 1
    • Open the latch that assesses the charging port.
    • Remove the black sticker and remove the screw with the indicated screwdriver.
  2. Logitech Harmony Touch Power Adapter Replacement: Schritt 2, Bild 1 von 2 Logitech Harmony Touch Power Adapter Replacement: Schritt 2, Bild 2 von 2
    • Take the plastic opening tool and run it down the side of the remote to pop the case open.
    • While doing this step there are three wires that connect the two pieces, be sure not to rip them out when opening.
    • Detach the white clamp to partially disconnect the case from the motherboard.
  3. Logitech Harmony Touch Power Adapter Replacement: Schritt 3, Bild 1 von 1
    • Once your device is open, check to see if wires are intact.
    • If wires are not intact, solder your wires back in place to ensure contact with your charging port.
Abschluss
USF Tampa, Team S4-G2, Eyestone Fall 2017 Mitglied von USF Tampa, Team S4-G2, Eyestone Fall 2017
USFT-EYESTONE-F17S4G2
4 Mitglieder
5 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 4
Letzte 30 Tage: 8
Insgesamt: 544
