Zum Hauptinhalt wechseln
Logitech Harmony Ultimate Charging Station Motherboard Replacement
Was du brauchst
  1. Logitech Harmony Ultimate Charging Station Motherboard Replacement, Charging Station Motherboard: Schritt 1, Bild 1 von 3 Logitech Harmony Ultimate Charging Station Motherboard Replacement, Charging Station Motherboard: Schritt 1, Bild 2 von 3 Logitech Harmony Ultimate Charging Station Motherboard Replacement, Charging Station Motherboard: Schritt 1, Bild 3 von 3
    • Screws are hidden beneath rubber pads.
    • Peel off the rubber pads.
    • Remove four 6mm screws Phillips #0 screws from the bottom of the device.
  2. Logitech Harmony Ultimate Charging Station Motherboard Replacement: Schritt 2, Bild 1 von 2 Logitech Harmony Ultimate Charging Station Motherboard Replacement: Schritt 2, Bild 2 von 2
    • Use the plastic opening tool to remove top shell from device.
  3. Logitech Harmony Ultimate Charging Station Motherboard Replacement: Schritt 3, Bild 1 von 3 Logitech Harmony Ultimate Charging Station Motherboard Replacement: Schritt 3, Bild 2 von 3 Logitech Harmony Ultimate Charging Station Motherboard Replacement: Schritt 3, Bild 3 von 3
    • Remove the two (4mm) screws using Phillips 1 screwdriver.
  4. Logitech Harmony Ultimate Charging Station Motherboard Replacement: Schritt 4, Bild 1 von 3 Logitech Harmony Ultimate Charging Station Motherboard Replacement: Schritt 4, Bild 2 von 3 Logitech Harmony Ultimate Charging Station Motherboard Replacement: Schritt 4, Bild 3 von 3
    • Use the Phillips #0 screwdriver to remove the last (4mm) screw. The motherboard can now be removed.
Abschluss
Lucas Reynolds
336 Reputation
2 Anleitungen geschrieben
USF Tampa, Team 8-1, Eyestone Fall 2015 Mitglied von USF Tampa, Team 8-1, Eyestone Fall 2015
USFT-EYESTONE-F15S8G1
5 Mitglieder
8 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 4
Letzte 30 Tage: 26
Insgesamt: 2,877
