Zum Hauptinhalt wechseln
Einleitung
Cables can be damaged. This guide will help when your damage your Logitech K120 keyboard’s USB cable.
Ersatzteile
Keine Ersatzteile angegeben.
  1. Remove the Phillips #000 screw. Turn the screwdriver counter-clockwise. Remove the Phillips #000 screw. Turn the screwdriver counter-clockwise.
    • Remove the Phillips #000 screw. Turn the screwdriver counter-clockwise.
  2. Use the spudger to separate the top of keyboard from the bottom of the keyboard. Use the spudger to separate the top of keyboard from the bottom of the keyboard. Use the spudger to separate the top of keyboard from the bottom of the keyboard.
    • Use the spudger to separate the top of keyboard from the bottom of the keyboard.
  3. Remove the top of the keyboard and put it aside.
    • Remove the top of the keyboard and put it aside.
  4. Unscrew the highlighted screws using a Phillips #000  Screwdriver. Turn the screwdriver counter-clockwise. Unscrew the highlighted screws using a Phillips #000  Screwdriver. Turn the screwdriver counter-clockwise. Unscrew the highlighted screws using a Phillips #000  Screwdriver. Turn the screwdriver counter-clockwise.
    • Unscrew the highlighted screws using a Phillips #000 Screwdriver. Turn the screwdriver counter-clockwise.
  5. Use the spudger and carefully pry the connector out of its socket. (Highlighted in the pictures) Use the spudger and carefully pry the connector out of its socket. (Highlighted in the pictures) Use the spudger and carefully pry the connector out of its socket. (Highlighted in the pictures)
    • Use the spudger and carefully pry the connector out of its socket. (Highlighted in the pictures)
  6. Carefully nudge the connector out of the hole in which the cable enters the keyboard's chassis. Carefully nudge the connector out of the hole in which the cable enters the keyboard's chassis.
    • Carefully nudge the connector out of the hole in which the cable enters the keyboard's chassis.
  7. Peel the membrane off carefully so that the membrane doesn't rip. Peel the membrane off carefully so that the membrane doesn't rip.
    • Peel the membrane off carefully so that the membrane doesn't rip.
  8. Stick the sharp end of the spudger into the corner of the second membrane and bring the spudger partly underneath the membrane. Lift the membrane off of the first standoff. Peel the rest of the membrane off carefully so the membrane doesn't rip.
    • Stick the sharp end of the spudger into the corner of the second membrane and bring the spudger partly underneath the membrane.
    • Lift the membrane off of the first standoff.
    • Peel the rest of the membrane off carefully so the membrane doesn't rip.
  9. Slide the new cable into the hole. Slide the new cable into the hole. Slide the new cable into the hole.
    • Slide the new cable into the hole.
  10. Connect The Cable To The Circuit Board. Connect The Cable To The Circuit Board. Connect The Cable To The Circuit Board.
    • Connect The Cable To The Circuit Board.
Abschluss
To reassemble your device, follow the instructions on how to reassemble your device in the prerequisite guide.
Marcus Jones
836 Reputation
6 Anleitungen geschrieben
Ein Kommentar
Hi there,
Nice guide! Where do I get hold of a replacement USB wire / what’s the specific name of it?
Thanks,
Robin
Robin Lane - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzten 24 Stunden: 2
Letzten 7 Tage: 10
Letzten 30 Tage: 50
Insgesamt: 796
