Zum Hauptinhalt wechseln
Logitech K480 Keycap Replacement
Was du brauchst
  1. Logitech K480 Keycap Replacement, Back Cover: Schritt 1, Bild 1 von 1
    • Flip the keyboard over.
  2. Logitech K480 Keycap Replacement: Schritt 2, Bild 1 von 3 Logitech K480 Keycap Replacement: Schritt 2, Bild 2 von 3 Logitech K480 Keycap Replacement: Schritt 2, Bild 3 von 3
    • Remove the four rubber feet with a spudger.
  3. Logitech K480 Keycap Replacement: Schritt 3, Bild 1 von 3 Logitech K480 Keycap Replacement: Schritt 3, Bild 2 von 3 Logitech K480 Keycap Replacement: Schritt 3, Bild 3 von 3
    • Slide open battery panel.
    • Remove the batteries.
  4. Logitech K480 Keycap Replacement: Schritt 4, Bild 1 von 2 Logitech K480 Keycap Replacement: Schritt 4, Bild 2 von 2
    • Remove the three 4 mm screws under the rubber feet using a Phillips #0 screwdriver.
  5. Logitech K480 Keycap Replacement: Schritt 5, Bild 1 von 2 Logitech K480 Keycap Replacement: Schritt 5, Bild 2 von 2
    • Remove the two 4 mm screws from beneath the battery cover using a Phillips #0 screwdriver.
  6. Logitech K480 Keycap Replacement: Schritt 6, Bild 1 von 3 Logitech K480 Keycap Replacement: Schritt 6, Bild 2 von 3 Logitech K480 Keycap Replacement: Schritt 6, Bild 3 von 3
    • Starting by the dial, slide the spudger between the front and back panels until it lifts and snaps.
    • Slide a blue pick in to keep the pieces apart while you work on other areas.
    • Continue prying along the edges until you have enough opened that you can pull both pieces apart gently with your hands.
    • The loud snaps are the clips that hold the pieces together. They're not breaking and you do not need to be alarmed.
  7. Logitech K480 Keycap Replacement, Metal Plate: Schritt 7, Bild 1 von 3 Logitech K480 Keycap Replacement, Metal Plate: Schritt 7, Bild 2 von 3 Logitech K480 Keycap Replacement, Metal Plate: Schritt 7, Bild 3 von 3
    • Remove the eight 3 mm screws using a Phillips #00 screwdriver
    • Remove the five 2 mm silver screws from the metal plate using a Phillips #00 screwdriver.
    • Remove the single 4 mm black screw by the motherboard using a Phillips #00 screwdriver.
  8. Logitech K480 Keycap Replacement: Schritt 8, Bild 1 von 2 Logitech K480 Keycap Replacement: Schritt 8, Bild 2 von 2
    • Lift up and remove the metal plate.
  9. Logitech K480 Keycap Replacement, Keycap: Schritt 9, Bild 1 von 1
    • Flip the flex circuit and rubber dome sheet over.
  10. Logitech K480 Keycap Replacement: Schritt 10, Bild 1 von 3 Logitech K480 Keycap Replacement: Schritt 10, Bild 2 von 3 Logitech K480 Keycap Replacement: Schritt 10, Bild 3 von 3
    • Using the spudger, gently press on the underside of the key and pop it out.
Abschluss
Madison
688 Reputation
4 Anleitungen geschrieben
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 4
Letzte 30 Tage: 27
Insgesamt: 436
