Zum Hauptinhalt wechseln
Logitech K860 Disassembly
Was du brauchst
  1. Logitech K860 Disassembly, Keyboard: Schritt 1, Bild 1 von 2 Logitech K860 Disassembly, Keyboard: Schritt 1, Bild 2 von 2
    • Unscrew all screws. Some screws are under the small resin stands.
    • Beware: One screw is placed right under the serial number on the sticker. This will void your warranty.
    • Edit: some plastic molds have two screws under the sticker. Location in photo.
  2. Logitech K860 Disassembly: Schritt 2, Bild 1 von 2 Logitech K860 Disassembly: Schritt 2, Bild 2 von 2
    • (It's not me, the resizing tool here is a joke.)
    • Anyway, you need to unclip the wrist pad and unscrew some stuff again. Like 4-5 screws here.
  3. Logitech K860 Disassembly: Schritt 3, Bild 1 von 1
    • Disconnect the on/off switch from the back cover.
    • As you can see, all the plastic standoffs are melted and squashed so that you can take this plate off but only once.
    • I tried to crush some of them. It's doable, but time-consuming. The keyboard probably wouldn't have the same rigidity after all this.
  4. Logitech K860 Disassembly: Schritt 4, Bild 1 von 1
    • Now you are left with this beautiful view. You can unscrew the ground for the small board and the board itself. You can even unscrew 2 screws on either side of the keyboard.
    • What you cannot do is to take this whole metal back-plate off. Logitech is trying make it impossible to clean this stuff and see the membrane trickery.
Abschluss
5 weitere Personen haben diese Anleitung absolviert.
AlexG
238 Reputation
1 Anleitung geschrieben
4 Kommentare zur Anleitung
Great guide! the part about the hidden screw under the serial number in particular was a life saver.
One thing that's not clear is which slots take the smaller vs the larger screws, it would help to annotate that as now I'm blindly screwing whatever fits.
michaelchirico4 - Antwort
OK so IINM, the 6 small screws all go on the upper half of the reverse side. There is also one slot for a longer screw (closest to the power switch). Anyway the longer screws don't fit in the small slots so it's easy.
michaelchirico4 -
Great guide. But I have 2 buttons that are not working, if it can not get to te membrane how can i test it or clean it?
Victor Araki Miyazono - Antwort
that's ridiculous that you can't do that. I have the same issue.
Artan Muzhaqi -
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 4
Letzte 7 Tage: 69
Letzte 30 Tage: 285
Insgesamt: 5,135
