Was du brauchst
Unscrew the Phillips #1 screw in the battery compartment after removing the battery.
Wiggle the grey part of the top to remove it by pulling it towards you(away from the scroll wheel).
Reasoning by Jacob Hickey "because in the internal top part of the mouse where the buttons/scroll wheel is, there’s hinges-like “tooth” that’ll snap if you do pull on it. It’s like opening a jewelry box that has a hinge on one end of the box… if that makes sense…"
Push back small black clips to release the circuit board.
Slide up the metal battery connectors to free them from the casing. (Note that these are soldered to the circuit board.)
Fully remove the circuit board with the battery connectors and image sensor still attached.
Working from back to front (left to right in the first image) unclip the first two pairs of black plastic clips.
Slide the black upper casing forwards over the mouse wheel whilst applying pressure the two front clips to release them.
Separate the two casing layers fully.
29 weitere Nutzer:innen haben diese Anleitung absolviert.
9 Kommentare
Thank you Karmanyaah Malhotra for takin’ the time to do this for everybody like me :-)
were can i buy these iems telll mee please
TElll me now or else
I will be sad
