Einleitung
This guide is to help you disassemble Logitech M331/M330 mouse and clean the mouse wheel.
Was du brauchst
Carefully detach the upper case and the lower case of the mouse by holding the lower case and lifting the upper case up and then pulling it backward.
Carefully detach the upper case and the lower case of the mouse by holding the lower case and sliding the upper case forward.
Unscrew the screw in the purple circle and unfasten the plastic pins in blue circles to remove the board from the plastic cover.
To disassemble the upper case of the mouse, detach the plastic pins located in the blue circles. The two pins located in purple circles will be automatically unfastened once the four blue pins are detached.
To disassemble the light propagator, detach the small plastic pin at the bottom of the mouse case and light propagator connection.
20 weitere Personen haben diese Anleitung absolviert.
7 Kommentare
first time using ifixit
this was just what i needed thanks!
Thanks for the guide! I was able to clean the scroll wheel properly and fixed the annoying inaccurate scroll issue.
Exactly what I needed, a clear and direct guide. Thank you so much!
Finally my mouse-wheel has stopped ghost scrolling, I used to have this problem where when I scrolled down and up it would go the opposite direction, at first I thought it was a bug but turns out on my other wired logitech mouse, it worked normally.
Upon following this instruction manual (A++) I managed to put some WD40 in the mouse wheel scrolling part, from the inside (not the wheel but the thing it’s attached to) and scrolled it a couple of times, now it works normally :)
Thanks to the author!
