Einleitung
Taking the outer shell off is very easy and all of the internals are visible when it is removed.
Ersatzteile
  1. Remove the battery hatch and batteries.
    • Remove the battery hatch and batteries.
  2. Kostenloser Versand für alle Bestellungen über 100,00 $ oder mit einem Pro Tech Toolkit!
    Schau dich im Store um
    Ever fixed something? That’s Genius.
    Share your repair story with #ImAGenius
    We Are All Geniuses
  3. Remove the single Phillips screw located between the battery sockets.
    • Remove the single Phillips screw located between the battery sockets.
  4. Lift the rear of the top case of the mouse and slide forward. It should be fairly easy to release.
    • Lift the rear of the top case of the mouse and slide forward. It should be fairly easy to release.
Abschluss
4 weitere Nutzer haben diese Anleitung absolviert.
Anna Sweetnam
232 Reputation
1 Anleitung geschrieben
I got to step 3. where is step 4?
hawaii50 - Antwort
What are you trying to do? All of the innards are available once step 3 is complete.
Anna Sweetnam - Antwort
Hi, just to say that its a utility named ProxyTool from Logitech that can be used to adjust the behavior of hand detection feature. here you go the file: ftp://ftp.logitech.com/pub/techsupport/m... or https://www.dropbox.com/s/z1rq7s6wzt4ohu...
You can literaly disable the Couch Mouse M515 hand proximity sensor
Luis Frederico - Antwort
Statistik anzeigen:
Letzte 24 Stunden: 2
Letzte 7 Tage: 17
Letzte 30 Tage: 74
Insgesamt: 3,284
