Zum Hauptinhalt wechseln
Logitech M535 Disassembly
Was du brauchst
  1. Logitech M535 Disassembly, Logitech M535: Schritt 1, Bild 1 von 1
    • This is how the mouse looks like once fixed
    Frag FixBot
    Kommentar hinzufügen
  2. Logitech M535 Disassembly, Open the battery box: Schritt 2, Bild 1 von 1
    • Slide the cover open to get to the battery
    Frag FixBot
  3. Logitech M535 Disassembly: Schritt 3, Bild 1 von 1
    • Pull the sticker inside of the battery box slowly: the glue is pretty strong and the space is tight. A butter knife works alright. You need to remove enough of the sticker to get to the bottom of the battery box.
    Frag FixBot
  4. Logitech M535 Disassembly: Schritt 4, Bild 1 von 1
    • The little screw is approximately there (it occurred to me I should write a guide only after I closed the mouse).
    • Gently pull apart the top and the bottom at this stage with some care to avoid breaking the internal plastic.
    Frag FixBot
Abschluss
4 weitere Personen haben diese Anleitung absolviert.
0 Kommentare zur Anleitung
Seitenaufrufe:
Letzte 24 Stunden: 5
Letzte 7 Tage: 11
Letzte 30 Tage: 70
Insgesamt: 3,313
