Einleitung
In this Guide I will show you how to replace a broken switch on a MX Anywhere 2. Also I am a beginner (meaning a 15 year old that likes to tinker with electronics), so don't expect Pro Advice.
Was du brauchst
First Remove the Mouse Skates. Then removes the 4 screws underneath.
Then take all the screws out remove the battery, the scroll wheel, and the PCB board.
Then, take the broken switch off the board. Once that is finished, get the new switch and put it up against the solder holes. Melt the solder and Insert the switch in the 3 holes.
Abschluss
Enjoy!
