Zum Hauptinhalt wechseln
Logitech Mouse G302 Disassembly
Was du brauchst
  1. Logitech Mouse G302 Disassembly, Open the case: Schritt 1, Bild 1 von 2 Logitech Mouse G302 Disassembly, Open the case: Schritt 1, Bild 2 von 2
    • Flip the mouse over to gain access to the bottom.
    • Using a scalpel, pick, or similar tool, peel away the slide pads on the bottom of the mouse in order to expose the three screws.
    • Using a PH0 / Phillips #0 driver, remove the 3 screws shown in red.
    • Peel away as little of the pads as possible, in order to preserve the adhesive on their undersides.
    • Gently separate the two halves of the case. Light prying may be required.
    • For PCB removal : remove 3 PH0 screws from PCB surface. The whole PCB can be taken out for inspection and repair after the screws are removed.
  2. Logitech Mouse G302 Disassembly, Switch replacement: Schritt 2, Bild 1 von 2 Logitech Mouse G302 Disassembly, Switch replacement: Schritt 2, Bild 2 von 2
    • The switch's brand is Omron. Part number: D2FC-F-7N. Components have 3 pins leaded type (two utilized)
    • I experienced one switch working intermittently. In such case, I recommend replacing both L & R switches.
  3. Logitech Mouse G302 Disassembly, Switch information: Schritt 3, Bild 1 von 1
    • This is helpful for finding the correct replacement or compatible replacement e.g. vendors from online store AliExpress.
    • I used this as a successful replacement: RS Components Stock No. 682-1519 microswitch. Manufacturer is Omron, manufacturer part number is D2F-F.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Ein Kommentar
what is the name and type of switch number 3 / sw3
Yanuar Arifiyanto - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 25
Letzte 30 Tage: 116
Insgesamt: 4,455
