Einleitung
1- Remove the cover where you replace the battery.
2 - Below each battery, there is a screw that you remove with a small Philips screwdriver.
3 - At the top of the back part of the mouse there are two rubber finishes that you remove (it has an adhesive) and there you will find the screws that hold the top.
4 - It gets loose immediately, please be careful with the wire that connects one part to another, please disconnect this wire.
Was du brauchst
Remove the battery housing screws on the bottom.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
100%
Hier starten ›
