Einleitung
This is a guide designed to assist you in removing and replacing the Logitech UE Megaboom Auxiliary and USB Ports.
Was du brauchst
Locate the ends of the speaker.
Put a plastic opening tool in-between the rubber end and the mesh.
Apply a upward force in order to pry open the end.
Apply this procedure to the other side as well.
Take the Jimmy and pry up the rubber strip that has the volume buttons on it.
Remove all the rubber you pried off.
Use tweezers to lift end of plastic retainer on edge of mesh out of its channel.
Work the plastic retainer out of the channel all the way around the speaker.
Repeat for other side.
Apply an upward force with your thumbs to loosen the end cap.
Grasp the end cap and lift up to seperate it from the base.
Use tweezers or an opening tool to remove the plastic insert on the inside of the rubber seal.
Push up on the rectangular connector from the bottom to loosen the circuit board.
Now grasp the plastic on the outside of the rubber seal and pull it out by applying an upward force.
Once the plastic has been removed, pull out the circuit board containing the auxiliary and USB ports.
3 weitere Personen haben diese Anleitung absolviert.
10 Kommentare
How can I purchase this part being replaced thanks
I also need this part due to water damage. Where Do I order this entire motherboard at?
Hello. Did you find the spare part?
Ionut -
I don’t think you can buy the parts new. Try buying a used/broken speaker for parts that has a working part that you need.
