Zum Hauptinhalt wechseln
Logitech UE MegaBoom Power Button Replacement
Was du brauchst
  1. Logitech UE MegaBoom Power Button Replacement, Outer Mesh: Schritt 1, Bild 1 von 3 Logitech UE MegaBoom Power Button Replacement, Outer Mesh: Schritt 1, Bild 2 von 3 Logitech UE MegaBoom Power Button Replacement, Outer Mesh: Schritt 1, Bild 3 von 3
    • Locate the ends of the speaker.
    • Put a plastic opening tool in-between the rubber end and the mesh.
    • Apply a upward force in order to pry open the end.
    • Apply this procedure to the other side as well.
    • Will take force.
    • Using metal tools may permanently mar your device.
  2. Logitech UE MegaBoom Power Button Replacement: Schritt 2, Bild 1 von 3 Logitech UE MegaBoom Power Button Replacement: Schritt 2, Bild 2 von 3 Logitech UE MegaBoom Power Button Replacement: Schritt 2, Bild 3 von 3
    • Take the Jimmy and pry up the rubber strip that has the volume buttons on it.
    • You will hear clicks as it pries up, don't worry.
    • Remove all the rubber you pried off.
  3. Logitech UE MegaBoom Power Button Replacement: Schritt 3, Bild 1 von 2 Logitech UE MegaBoom Power Button Replacement: Schritt 3, Bild 2 von 2
    In diesem Schritt verwendetes Werkzeug:
    • Use tweezers to lift end of plastic retainer on edge of mesh out of its channel.
    • Work the plastic retainer out of the channel all the way around the speaker.
    • Be gentle, it is easy to damage the fabric.
    • Repeat for other side.
  4. Logitech UE MegaBoom Power Button Replacement, Power Button: Schritt 4, Bild 1 von 2 Logitech UE MegaBoom Power Button Replacement, Power Button: Schritt 4, Bild 2 von 2
    • Locate the end of the speaker which contains the power button.
    • The circuit board which contains the power button should be visible.
    • Grasp the outer rim of this end cap and pull in an upward motion.
    • This might require some force.
  5. Logitech UE MegaBoom Power Button Replacement: Schritt 5, Bild 1 von 1
    • Insert a opening tool between the circuit board and one of the black clips which is holding the board in place.
    • Using the opening tool pry up on the clip allowing the board to be freed. Pry up on the second clip to fully release the board.
    • Using your fingers lift the board out of place.
Abschluss
Eine weitere Person hat diese Anleitung absolviert.
Oscar Ambriz
977 Reputation
6 Anleitungen geschrieben
Cal Poly, Team S9-G2, Banghart Fall 2017 Mitglied von Cal Poly, Team S9-G2, Banghart Fall 2017
CPSU-BANGHART-F17S9G2
4 Mitglieder
17 Anleitungen geschrieben
3 Kommentare zur Anleitung
Will it still be waterproof after repairing?
TechBrush - Antwort
that would be a negative unless you really know what you are doing and can waterproof it
Justin Doubikin -
nice piece. i was able to follow the guide and got it right taking out the board. please where can one purchase the power button board. thanks
tony - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 8
Letzte 30 Tage: 48
Insgesamt: 4,990
