Einleitung
Prerequisite only guide to open the Logitech VX Nano Wireless Mouse.
Was du brauchst
Pull down on the battery release tab to remove the battery cover.
Remove battery cover.
Pull the battery release tab away from the mouse so the two AA batteries come out.
If the Nano Receiver is still in the mouse and not in your computer, remove it by pushing on the bright orange button. It should pop right out!
Find and remove the screws at the bottom of the battery compartment:
Two 6 mm Phillips #1 screws
Use an opening pick to get underneath the corner of one of the adhesive skates.
Continue to push the opening pick between the adhesive and the mouse case, slowly working the adhesive away from the case.
Repeat this same process for the two other skates.
Remove the screws from the backside of the mouse:
Three 6 mm Phillips #1 screws
Carefully separate the top plastic shell from the bottom case.
Remove the top shell.
