Zum Hauptinhalt wechseln
Logitech Webcam Pro 9000 Front and Back Cover Replacement
Was du brauchst
  1. Logitech Webcam Pro 9000 Front and Back Cover Replacement, Front and Back Cover: Schritt 1, Bild 1 von 2 Logitech Webcam Pro 9000 Front and Back Cover Replacement, Front and Back Cover: Schritt 1, Bild 2 von 2
    • Remove the two 8 mm Phillips #0 screws on the back cover.
    • The motherboard connects the two covers together. DO NOT separate the two yet.
    • There is a button that loosens as the Phillips screws are removed. Don't be alarmed if it falls out.
  2. Logitech Webcam Pro 9000 Front and Back Cover Replacement: Schritt 2, Bild 1 von 2 Logitech Webcam Pro 9000 Front and Back Cover Replacement: Schritt 2, Bild 2 von 2
    • Remove the four 6mm Phillips #0 screws connecting the motherboard and front cover.
    • DO NOT detach the wire connecting the motherboard to the front cover.
Abschluss
Cal Poly, Team 12-34, Amido Spring 2013 Mitglied von Cal Poly, Team 12-34, Amido Spring 2013
CPSU-AMIDO-S13S12G34
4 Mitglieder
16 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 8
Letzte 30 Tage: 13
Insgesamt: 1,246
