Einleitung
There are two parts to the microphone: the cover and the microphone and its casing. It takes about the same amount of time to remove the cover and the microphone.
Was du brauchst
Remove the four 6mm Phillips #0 screws connecting the motherboard and front cover.
Grasp the white wire connector between the tabs and the socket.
Wiggle the connector back and forth to remove the front cover from the motherboard.
Wedge the plastic opening tool into the crack between the plastic cover and microphone guard.
Use the wedge to separate the two pieces.
2 weitere Personen haben diese Anleitung absolviert.
