Zum Hauptinhalt wechseln
Logitech WiLife and LukWerks Outdoor Security Camera Capacitor replacement
Was du brauchst
  1. Logitech WiLife and LukWerks Outdoor Security Camera Capacitor replacement, Capacitors: Schritt 1, Bild 1 von 3 Logitech WiLife and LukWerks Outdoor Security Camera Capacitor replacement, Capacitors: Schritt 1, Bild 2 von 3 Logitech WiLife and LukWerks Outdoor Security Camera Capacitor replacement, Capacitors: Schritt 1, Bild 3 von 3
    • Obtain (4) 1000uF capacitors rated for 25 volts. The replacement capacitors featured in this guide were purchased from Digi-key. Digi-key part number: UHE1E102MHD6. http://search.digikey.com/scripts/DkSear...
    • Additional suggested tools for this repair are pictured.
    Frag FixBot
  2. Logitech WiLife and LukWerks Outdoor Security Camera Capacitor replacement: Schritt 2, Bild 1 von 1
    • Caution: Be mindful of the dangerous high voltage that exist in this device when powered and for a short time afterward.
    • Place the camera upside down.
    • Using a small flat tool, pry off the plastic covers on each side of the case (outlined in orange)
    Frag FixBot
  3. Logitech WiLife and LukWerks Outdoor Security Camera Capacitor replacement: Schritt 3, Bild 1 von 1
    • Removal of the covers reveal six philips head screws (green highlight).
    • Unscrew all six screws.
    Frag FixBot
  4. Logitech WiLife and LukWerks Outdoor Security Camera Capacitor replacement: Schritt 4, Bild 1 von 2 Logitech WiLife and LukWerks Outdoor Security Camera Capacitor replacement: Schritt 4, Bild 2 von 2
    • Flip the camera so the top is right-side up.
    • Remove the top of the case.
    • Notice the four damaged capacitors C26, C27, C31 and C32 (red highlight).
    Frag FixBot
  5. Logitech WiLife and LukWerks Outdoor Security Camera Capacitor replacement: Schritt 5, Bild 1 von 1
    • Unscrew all four phillips head screws in each corner (green highlight).
    • Disconnect power cable (yellow highlight).
    • Lift and remove the clear front plastic lens cover.
    • Lift the circuit board and camera assebly out of the case.
    • Carefully separate the LED assembly from the four small connectors (highlighted in blue). Note: This step is not required for this repair. However, it reduces the possibility of inadvertent damage during the process.
    Frag FixBot
  6. Logitech WiLife and LukWerks Outdoor Security Camera Capacitor replacement: Schritt 6, Bild 1 von 3 Logitech WiLife and LukWerks Outdoor Security Camera Capacitor replacement: Schritt 6, Bild 2 von 3 Logitech WiLife and LukWerks Outdoor Security Camera Capacitor replacement: Schritt 6, Bild 3 von 3
    • Desolder and remove the four capacitors (red highlight).
    • Suggestion: Mark the capacitors on top and on the bottom of the board to avoid damaging another component.
    Frag FixBot
  7. Logitech WiLife and LukWerks Outdoor Security Camera Capacitor replacement: Schritt 7, Bild 1 von 1
    • Clean and remove remaining solder or debris from the area.
    • Cut leads on new capacitors to fit.
    • Solder the four new capacitors in place.
    • Notice: Pay attention to the polarity of the capacitors.
    • Insulate the leads and gently bend the capacitors to fit.
    Frag FixBot
  8. Logitech WiLife and LukWerks Outdoor Security Camera Capacitor replacement: Schritt 8, Bild 1 von 1
    • Suggestion: Before full reassembly, reattach the LED module, place the board and camera module into the case and reconnect the A/C cable to ensure proper operation.
    Frag FixBot
Abschluss
6 weitere Personen haben diese Anleitung absolviert.
1 Kommentar zur Anleitung
I did the repair worked for 5 min's then starts acting up. Before the fix wouldn't work at all. Is there anymore suggestions?
martin - Antwort Teilen
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 13
Letzte 30 Tage: 55
Insgesamt: 10,155
