Einleitung
Replacing the trucks of your skateboard is simple, and you only need the ability to use simple tools! Follow this easy step-by-step instruction to get new trucks on your board. For this installation you will need a phillips or flathead screwdriver. Be sure when you are removing and reinstalling hardware that you pay close attention to individual components. Missing or improperly installed parts could lead to injury of yourself or others. This installation guide will have you ripping up the roads in 20 minutes or less!
Was du brauchst
Use a Phillips/flat head screw driver, along with a skate tool or set of pliers, to loosen the nuts which fasten the trucks to the deck.
Clean the hardware by either soaking it in cleaning solution, or by manually cleaning it with a moist cloth.
After re-installation, check and confirm that all the bolts and nuts are tight. The bolts should be slightly submerged in the wood of the deck
After re-installing the trucks, check and confirm the kingpin is facing outward.
Now you’ve completed the guide ‘How to clean and maintain skate/longboard trucks. Your longboard should look like the picture. Before riding, as a final precaution, make sure every piece is securely fastened and the trucks are facing the correct way. Have fun and always wear a helmet!
Eine weitere Person hat diese Anleitung absolviert.
