Zum Hauptinhalt wechseln
Lorex LW2742 Microphone Replacement
Was du brauchst
  1. Lorex LW2742 Microphone Replacement, Microphone: Schritt 1, Bild 1 von 2 Lorex LW2742 Microphone Replacement, Microphone: Schritt 1, Bild 2 von 2
    • Remove the six 10mm Torx T10 screws on camera face.
  2. Lorex LW2742 Microphone Replacement: Schritt 2, Bild 1 von 1
    • Remove the exterior lens cover.
  3. Lorex LW2742 Microphone Replacement: Schritt 3, Bild 1 von 3 Lorex LW2742 Microphone Replacement: Schritt 3, Bild 2 von 3 Lorex LW2742 Microphone Replacement: Schritt 3, Bild 3 von 3
    In diesem Schritt verwendetes Werkzeug:
    Kaufen
    • Remove the LED foam ring with tweezers.
    • Be aware, the electronic components of the LED board may be compromised if you use your fingers instead of tweezers for this step.
  4. Lorex LW2742 Microphone Replacement: Schritt 4, Bild 1 von 1
    • Remove the two 5mm Phillips #1 screws.
    • Remove the two 8mm Phillips #0 screws.
    • When reassembling, tighten the left and right 8mm screws first. Followed by the top and bottom 5mm screws.
  5. Lorex LW2742 Microphone Replacement: Schritt 5, Bild 1 von 1
  6. Lorex LW2742 Microphone Replacement: Schritt 6, Bild 1 von 3 Lorex LW2742 Microphone Replacement: Schritt 6, Bild 2 von 3 Lorex LW2742 Microphone Replacement: Schritt 6, Bild 3 von 3
    • Use tweezers to disconnect the microphone wires from the internal components of camera.
  7. Lorex LW2742 Microphone Replacement: Schritt 7, Bild 1 von 3 Lorex LW2742 Microphone Replacement: Schritt 7, Bild 2 von 3 Lorex LW2742 Microphone Replacement: Schritt 7, Bild 3 von 3
    • Remove the 4mm Flathead #4 screw on the bottom of the camera.
    • Remove the weatherproof gasket around the microphone with tweezers.
  8. Lorex LW2742 Microphone Replacement: Schritt 8, Bild 1 von 3 Lorex LW2742 Microphone Replacement: Schritt 8, Bild 2 von 3 Lorex LW2742 Microphone Replacement: Schritt 8, Bild 3 von 3
    • Remove the microphone.
    • Push the microphone from the inside out for easier removal.
Abschluss
USF Tampa, Team 16-1, Eyestone Fall 2016 Mitglied von USF Tampa, Team 16-1, Eyestone Fall 2016
USFT-EYESTONE-F16S16G1
4 Mitglieder
12 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 11
Insgesamt: 264
