Zum Hauptinhalt wechseln
Lorex LW2742 Speaker Replacement
Was du brauchst
  1. Lorex LW2742 Speaker Replacement, Back Panel: Schritt 1, Bild 1 von 3 Lorex LW2742 Speaker Replacement, Back Panel: Schritt 1, Bild 2 von 3 Lorex LW2742 Speaker Replacement, Back Panel: Schritt 1, Bild 3 von 3
    • Remove the battery cover on the back of the LCD monitor by unscrewing one 5mm Phillips #1 screw.
    • Slide the battery out of the housing. Lightly tap the opposite end of the monitor if the battery does not come right out.
  2. Lorex LW2742 Speaker Replacement: Schritt 2, Bild 1 von 1
    • Remove the four 6mm Phillips #1 screws on the back of the LCD monitor.
  3. Lorex LW2742 Speaker Replacement: Schritt 3, Bild 1 von 2 Lorex LW2742 Speaker Replacement: Schritt 3, Bild 2 von 2
    • Using a plastic opening tool, gently separate the back panel from the front panel, working the tool around the panel to disconnect it.
    • Carefully remove the back panel
    • The speaker wire is connected to the motherboard so DO NOT rip back panel away from the monitor.
  4. Lorex LW2742 Speaker Replacement, Speaker: Schritt 4, Bild 1 von 3 Lorex LW2742 Speaker Replacement, Speaker: Schritt 4, Bild 2 von 3 Lorex LW2742 Speaker Replacement, Speaker: Schritt 4, Bild 3 von 3
    • Locate the motherboard and carefully pull the red and black speaker wires out of their harness.
  5. Lorex LW2742 Speaker Replacement: Schritt 5, Bild 1 von 2 Lorex LW2742 Speaker Replacement: Schritt 5, Bild 2 von 2
    • Using a metal spudger, pry the melted black plastic away from the speaker.
    • Carefully pull the speaker out of its housing by the wires.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
USF Tampa, Team 16-1, Eyestone Fall 2016 Mitglied von USF Tampa, Team 16-1, Eyestone Fall 2016
USFT-EYESTONE-F16S16G1
4 Mitglieder
12 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 12
Insgesamt: 203
