Zum Hauptinhalt wechseln
Einleitung
This guide shows how to remove the battery cover and battery of this device. It shows the location of the screw and where to insert the spudger.
  1. Remove the 5.0mm screw using the Phillips #0 head screwdriver.
    • Remove the 5.0mm screw using the Phillips #0 head screwdriver.
  2. Insert metal spudger as shown in the picture. Move spudger along  to the other side until both snaps come loose.
    • Insert metal spudger as shown in the picture. Move spudger along to the other side until both snaps come loose.
  3. Android Fix Kits
    Ein neues Display oder Akku sind nur ein Kit entfernt.
    Jetzt kaufen
    Android Fix Kits
    Jetzt kaufen
  4. Picture shows the removed battery cover.
    • Picture shows the removed battery cover.
  5. Slide the battery out by pulling on one of two plastics tabs.
    • Slide the battery out by pulling on one of two plastics tabs.
Abschluss
Yancey Crase
217 Reputation
2 Anleitungen geschrieben
IUPUI, Team S1-G4, Harley Spring 2018 Mitglied von IUPUI, Team S1-G4, Harley Spring 2018
IUPUI-HARLEY-S18S1G4
7 Mitglieder
5 Anleitungen geschrieben
Kommentar hinzufügen
Statistik anzeigen:
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 11
Insgesamt: 224
